Changing the regulator on LPG tank (1 Viewer)
JackieP
666
1,400
Isle of Man
Since 2006
Evening all.
I've been having some problems lighting my gas water boiler and one of the suggestions has been to change the regulator. In the old days I just bought one and fitted it to the Gaslow bottles. Now I have an underslung tank and I haven't a clue how to fit a new one.
Any ideas?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Remove the tank cover and turn the tank isolation valve off. The rest will be obvious
Techno
Jul 28, 2010
15,475
20,756
May 2010
Best thing to do is establish what regulator you have just now (PICTURE) then we can find a replacement for you.
J
JackieP
666
1,400
Isle of Man
Since 2006
Thank you techno. I'm on my phone with little data but will take a picture and upload it soon as I can find wifi.
I do know it's a 50mb system due to the age and origin (Germany) of the van.
J
JackieP
666
1,400
Isle of Man
Since 2006
Do you know.... If the system was fitted in December 2014, would you expect to have to fit a new regulator by now?
Mar 11, 2013
1,280
1,678
Gillingham
coachbuilt
since 2005
I bought a spare regulator from gas it about £20.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The regulator will need to be matched to the equipment in the van. Modern regulators are 30mb but if your equipment is jetted for 50 it will be starved with a 30mb one
J
JackieP
666
1,400
Isle of Man
Since 2006
I took the cover off but nothing seemed very obvious (to me). There is something above that looks like a regulator so I've posted that too.
J
JackieP
666
1,400
Isle of Man
Since 2006
Yes. All the equipment inside is still rated st 50mb. 30 years old and still working. Apart from that pesky boiler.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes the something above is the regulator. You need a close up of the yellow label (clean it first) and whether the gas pipe is 8mm or 10 mm
J
JackieP
666
1,400
Isle of Man
Since 2006
First picture is how it looks. Second shows label 'flipped' to make it easier to read.
J
JackieP
666
1,400
Isle of Man
Since 2006
I was thinking that it would just be question of buying a new one and putting it on - as it used to be with the bottles. I can see that this is more complicated - and it's only a chance that it's the regulator at fault.
Flamenca
1,266
804
Europe
Hymer 564
Since 2010
@JackieP I replaced the regulator on my old Hymer. I had to buy an adapter which enabled me to use a standard propane regulator with hose connector. I know this is not what is done nowadays with 'standardisation' and using 'tails' but it enabled me to make a straight substitute.
J
JackieP
666
1,400
Isle of Man
Since 2006
If everything else is working I would have your boiler looked at
I'm having this done next week. Without seeing it the gas man has decided I need a new boiler at s cost of £850 What I'm trying to do is try some possible cheaper solutions first.
I read that the boiler is the last in line and that's why the other appliances may work fine but the boiler will fail to light if the regulator is past its best.
J
JackieP
666
1,400
Isle of Man
Since 2006
Thanks for the link Techno. That looks right and not too expensive either!
