- Jul 6, 2009
- 2,873
- 3,809
- Burstner A Class 736
This is the second Cello tv I have had with this problem. The TV is supplied by a stabilised 12 volt supply, it started a few days ago where you would turn the power on an it would take a few seconds for the standby light to come on, then a bit longer then not at all. Tried switching the actual switch on and off it then came on. Today nothing Have had the cover off to check the switch and circuit. There is continuity from the 12 volt socket to the switch and then to the board but no luck. Bit miffed as although this one was bought it 2020 it has not had much use and is mounted on a shock absorber mount. any suggestions Please?
