Markas
- Jul 13, 2017
- 128
- 130
- Van conversion
- Off and on since 2015
When I was in the UK in November I took my van back to the IH factory for a hab check and service and to pick up some warranty issues, one of which was the external temperature sensor not working.
They weren't able to fix it as the part wasn't in stock so I left it as it's easy to learn the outside temperature by sticking a body part out a window!
Since then however, the interior temperature sensor has also failed - showing 0.0 degrees all the time, and I was woken 8n the middle of the night to much beeping a couple of nights ago.
Turned out both water tank sensors had failed so I was being told I had no fresh water and a full grey water tank.
My quick fix has been to unplug both sensors on the distribution board to cut down the b**dy beeping, but has anyone experienced anything similar and might help me identify what's going on here?
Four sensors 'failing' in a short time makes me think they are not at fault and the problem lies elsewhere.
