- Dec 24, 2014
- 10,244
- 54,784
- Compass Navigator
- Ever since lighting was by Calor gas.
At 6 a.m. yesterday I switched on the water heater then hopped back into bed with a brew. 20 mins later a mighty thump shook the body, the pump started running and water began to run out from under the Carver heater locker.
In short the steel tie rod (Item 23) holding the whole heater assembly together had broken at where the threaded end enters the alloy heat exchanger casting.
It should be like this:
However, on disassembly I found that the tie rod had snapped due to corrosion at the threaded end and the end was stuck flush with the heat exchanger casting:
The casting with the broken end (photo above) is currently soaking in releasing fluid before I attempt to remove it using an 'EasyOut' drill bit. I'm not keen to try heat as the casting is probably the cheap 'n nasty reclaimed alloy from washing machines or whatever.
A plate on the Carver unit identifies it as from 1994 so it hasn't done too badly. The unit itself is obsolete although following my eBay search it appears that the tie rod is still available at £35.
A Propex Malaga E5 is said to be a direct and complete replacement for the Carver but at £462 I'd rather restore the Carver.
Keeping everything crossed that I'll be able to extract the broken bit and reassemble with a new tie rod.
