- May 23, 2013
- 1,782
- 2,816
- Hymer B504
- Since 2013
Thanks.I purchased the suction cups at Carthago City HQ quite a few years ago when you could buy spare parts over the counter. However, they no longer provide this service.
I don't know whether Carthago still stock these parts as the later mirrors are a different design and don't require the suckers.
I've now run out of the Carthago suckers and now buy from "suction cups direct" 47mm dia with brass nut. I use these in conjuction with a small aluminium offset bracket. The brass nut needs to be secured with thread-lock otherwise the vibration will loosen it.
Thanks.
Is the bracket to stop them pulling through ?
Anyone know how to adjust the top pivot mech to increase the spacing from the window ?
I've looked inside the rubber boot at the top and loosened the nuts but it doesn't seem to want to move further away before the spring brings it back.
Thanks I'll have a closer look.Once you've losened the top & bottom nuts there is a set-screw either side which controls the travel of the arm. I found out by trial and error. It would be good to have some definitive instructions on the adjustment process and the torque settings of the top & bottom nuts.
The manufacturer of the bus wing mirrors is Mekra, the UK distributor is located in Worthing, West Sussex, Tel 01903 206 106 or email info@mekra.co.uk or website https://www.mekra.co.uk/recreational/
