Jim
Ringleader
This thread is for the general discussion of the Article CAN YOU JUST SWAP YOUR LEAD ACID BATTERY FOR LITHIUM?.
Ill add my thoughts..This thread is for the general discussion of the Article CAN YOU JUST SWAP YOUR LEAD ACID BATTERY FOR LITHIUM?.
Understand your points, however in real world application, the BMS handles this. Effectively it doesn’t matter what your charging infrastructure (mains, engine and solar) presents to the batteries, the BMS will only use the power it needs.Ill add my thoughts..
The points made are all valid...but the real elephant in the room so to speak when we talk about replacing lead acid with lithium is that all the charging sources whilst claiming to use a lithium profile continue to hold the batteries at the upper end of their state of charge...if we are to believe what we read then this isn't ideal either but it's claimed its a low enough level to not cause harm... that to me is still a throwback to a lead acid charging regime ...ideally the charging sources should just stop charging When the batteries are full..and the batteries then loaded and used ...the charging sources switching back on again at a predetermined lower state of charge ..that would be a correct charging regime for lithium imo..
In other words you may have the batteries back up to a fully charged state after one hours drive...but you may be on the road for hours..holding the batteries at that high level..
Same with mains or solar charging... the batteries are brought to fully charged and held there while the charger often then continues to supply loads up to its max current capacity..the batteries only making up a shortfalls.. my thoughts have always been that the charging source should be removed when the batteries are fully charged..
Just like you use the other lithium chemistry batteries in say your phones..ie charge it and use it..not keep it on charge once its charged..
So to me until you install chargers that are capable of switching off and on at defined limits of charge and discharge you do not really have a correct lithium charging set up just another compromise..
Andy...
But my point is that whatever way you wrap it up... the point made is that lithium do not need or by all accounts want to be held at the upper end of their soc...they are because we have adapted a regime that was used for a different technology... it wasn't designed from the ground up to deal with lithium..the industry added a lithium profile to chargers but in an ideal world that profile would provide for a cessation of charging...Understand your points, however in real world application, the BMS handles this. Effectively it doesn’t matter what your charging infrastructure (mains, engine and solar) presents to the batteries, the BMS will only use the power it needs.
If it is Euro 6D it should have one but manufacturers tend to only fit a 30amp B2B. So for serious off grid use you will probably need to upgrade it to a more powerful one.Am I right in reading that any Euro6 engine will have a B2B system fitted?
Fiat vans had smart alternators on all Euro 6 versions but they were supplied to the Motorhome manufacturers with standard alternators until 2019 when the Euro 6D came out. I think only on 2020 year models they have smart alternators so from around September 2019. Mercs have had smart alternators on Motorhomes since around 2014/2015.It‘s Euro6b. Does that make a difference? The article refers to Euro6 only.
Look at the starter negative battery post. If the cable is directly bolted to the battery, then you have a conventional alternator. If the cable is attached to a shunt resistor, that’s attached to the battery post, then you have a smart alternator. The ecu uses the shunt data to control the alternator.It‘s Euro6b. Does that make a difference? The article refers to Euro6 only.
Look on the bright side if it doesn't have a B2B you won't be throwing away a working B2B to replace it with a better one.Typically ours is a 2019 Euro6b…
I've just checked voltage and its sitting at 12.7
My own personal view is very similar to eddievanbitz. I just can't see the point of paying a larger amount of money for a better product, if you're not going to get the advantages it can deliver?
Besides, the correct chargers for LiFePO4 don't just protect your battery investment. They can also protect your van.
I was quite an early adopter of lithium batteries, buying them in January 2018 to upgrade our van ready to go fulltime. Back then, there was very little mainstream information about the technology, so I spent a very long time learning everything I could before purchasing. This I had a lot of help with, especially from Gromett who would dig out industry articles for me, then we would discuss every aspect - often over weeks before drawing conclusions.
The bottom line is LiFePO4 is a very different technology to Lead Acid, therefore it needs charging in a different way.
With Lead Acid, what we try to do is fill the batteries to the max as quickly as we can. These batteries last longer if kept almost full but will fight against being fully charged. They become more resistive as they are filled. A smart charger can completely fill a Lead Acid battery over time, far better than a split charger, as it uses different stages of charging. So with Lead Acid, a smart charger is used to keep the battery full. Adding a larger smart charger won't necessarily charge a Lead Acid battery faster. The battery decides how much current to take, not the charger how much to provide.
With LiFePO4, it's the other way around. These batteries have next to no resistance to charging, making them very efficient at filling quickly. They are greedy and will take as much charge as they can, but to keep them in prime condition, should not be full all the time.
A smart chargers purpose with LiFePO4 isn't just to charge, it's to protect the battery from itself.
Most LiFePO4 batteries can be charged at a much higher rate than Lead Acid batteries. For instance, my battery can safely be charged at 200A per hour and will try to pull far more. Without a smart B2B to LIMIT the charge while driving, my battery could be overcharged. Also, I don't think my alternator would last very long.
I fitted what I believed to be the best charging system available at the time, along with 400Ah of Winston cells and a very smart BMS, which all worked very well - but not perfect.
The issue was that my chargers, although all set with the correct lithium profiles would trip my BMS sometimes. My BMS will stop charge going into the battery once the cells balance at 3.4v each (13.6v total). It's wasn't a major issue as that's what my BMS should do and cutting the charge doesn't stop the battery being discharged (my BMS uses separate relays for charging and loads). Charging would automatically start again when the battery state hit 95%. The trouble was, this kept the batteries fairly full, which wasn't ideal.
My chargers had set profiles that couldn't be altered, and I have my battery set quite conservatively, to prolong it's life. So I swapped all but my B2B to Victron last year, where the settings could be tweaked. I set my MPPT and EHU charger to deliver a slightly lower voltage so they never quite fill the battery. This is especially useful in the Winter while we are using EHU as my batteries are always in their sweet spot. Looking at the app now, my cells are 78% full, I'm using 6.4A and I'm charging at 5.8A. If I were upgrading today, I'd swap the B2B to Victron as well.
So now I have a system that is as close to ideal (for me) as I can get it. My batteries are well protected, my alternator is well protected, my BMS shuts down and auto restarts as an insurance policy and my battery is always in its happy place. I couldn't do this with most chargers.
I know that I now do this for a living and some of you might think me biased, but all of the above I bought and upgraded way before I started installing others systems. It's what I did spend my money on and would again if I were buying now.
Another point made in this thread was cost. I've just done a quick search on products I am happy with and would recommend, to see what the parts could be bought for.
I chose the following:
Roamer 300Ah battery - £1305
Victron 100/30 MPPT - £192
Victron 12/12/30 B2B - £194
Victron SmartShunt - £108
Victron IP22 30A EHU Charger - £170
So without upgrading wiring, the parts come to just under £2000. Thats for all great parts, all Bluetooth and all tweakable. Considering the battery is almost 2/3rd's of the total cost, is it really worth risking not having great charging?
Anyway, that's my opinion
The Resting or winter charging held by use of a Battery negative Issolator, is again a compromise, but works. so I've added an extra level of control. The control location could be tweaked (ie the charge going to the battery) but the system is proven to work. Simply I use a BMV712s ability to control a SSR based on SOC. Currently for winter i set the limmits to 65% relay off 40% on (ie allow solar charge) . For summer could reset to 90% max. I Have 2 circuits one 1 330w solar panel to SSR to Votronics MPPT. 2nd 220W to Duo MPPT Bat 1 to SSR2 to LB, Bat 2 trickle charge to SB. THe Votronics B2B currently is allowed to just do its thing. The SSR use 15mA 12V auto relays 300mA.Ill add my thoughts..
Andy...
