Can anybody identify this hob in thephoto
Photos of Hymer hob
Looks like a Smev 3 burner triangular hob we had that one in our old N+B .
Razzmatazz I cannot identify the model / make as I want to replace it like for like I hope.
Think it's this SMEV (on EBay for £139.95) - looks like it ...
Says it is a SMEV PI9003 3 BURNER HOB TRIANGULAR HOB ...
Had to replace ours couple of years ago.
Ours is a different shape, 3 rings, found one on Internet, cheaper than original without the drain plug-hole, dimensions the same and works just as well!
The new versions look to be slightly smaller/different shape to the one you have so make sure you get a template of the new one to check first before buying as I think your existing 'hole' might be too large and you'll end up having to change the worktop too.
I gave you a link to one that I think is the same on one of your other threads.
Why have you started 3 separate threads on it, just confuses people?
The hob shown in your pics is exactly the same as in my 2010 Carthago....except mine has individual pan supports.
Its a Dometic Cramer. I'd be very surprised if they still produce that model.
Edit: Ah, still in production according to rb62 post :giggle:
Nah I think he's got a bad memory .... :giggle:
Actually the Smev one you've mentioned and by others too isn't a 'like for like' replacement as the shape is different, hence my comments earlier.
I really must thank everybody for their help in helping source the hob I was looking for. The one I wanted was the Cramer/ Dometic. Sod’s law it will cost all most 50% more than the eBay one , but which would have been to small. The Cramer is exactly the same. Thanks again.
Colyboy
