hi ,,could anyone tell me how these aires work i have looked at the signs a few times but still unsure can i just turn up and pay or do i need to get a card before hand ,,thanks CAMPING-CAR PARKS ,,
hi thanks are the instructions in English i remember going to the barriers on another similar one in France and had to back away as couldn't get in or understand how to get in ,,Turn up.Card is issued from machine €5 charge for,card plus your over night fee. Or stay for 5 hours (I think)for €5 just to fill up etc
brilliant thanksOnce you've got your card, either from the machine or by post (takes a while to come) you just keep using the same card. You just need the card to get in but need enough balance on the card to pay for your stay to get out.
You can call for help from the barrier machine. They speak English.
You can change the language on screen to English (en)hi thanks are the instructions in English i remember going to the barriers on another similar one in France and had to back away as couldn't get in or understand how to get in ,,
thanks puts you under pressure if your at the gate and cant work out how do get in ,,im bad enough trying to put fuel in ,,when its in french ,,spent 5 mins trying to wok out what the pump was wanting the last time ,,turns out it was asking for a loyalty card ,,You can change the language on screen to English (en)
Just don't get stuck behind a French van, they haven't a clue, they often sit at the barrier for 20 min then give up and reverse out.thanks puts you under pressure if your at the gate and cant work out how do get in ,,im bad enough trying to put fuel in ,,when its in french ,,spent 5 mins trying to wok out what the pump was wanting the last time ,,turns out it was asking for a loyalty card ,,
Been caught by that one.And sometimes there are two machines. One for the payment and then another to open the barrier!
Some of the locals can't do it eitherhi thanks are the instructions in English i remember going to the barriers on another similar one in France and had to back away as couldn't get in or understand how to get in ,,
hi thanks i will have a look at doing that ,,You’ll get in eventually but be prepared for a bit of a struggle if you’re getting a card for the first time. If you’ve got the time it’s far far better to pre order the card before you travel. It has the advantage of registering yourself and your payment method online, making future top ups very simple.
And you have to be right up to the barrier before it opens too.And sometimes there are two machines. One for the payment and then another to open the barrier!
Always I thinkAnd sometimes there are two machines. One for the payment and then another to open the barrier!
No. From the initial screen that is in a large box and very easy to useAnd you have to be right up to the barrier before it opens too.
Well all the ones I've been on you have practically had to put the front of the van onto the barrier.No. From the initial screen that is in a large box and very easy to use
To the barrier side of this is a small keypad. Sometimes on a post. Hold your new card to this. Same as contactless payment
The barrier will open
You don’t need to be within an inch of it
You do not need to pay for the night before going on just before you leave
You can do this very easy on the screen
I fell foul of this recently. My card wouldn’t raise the barrier so I put more money on the card, waived it around and around, closer, further away. So finally phoned the contact us number and told them “card no open barrier madam”. “Pull forward” she says, “Oh yes, it’s worked now. Cheers”Well all the ones I've been on you have practically had to put the front of the van onto the barrier.
Currently they are only in France.. rumours that they are looking in the UK though.Are these just in France ? If not how do you see other countries pls
They have just opened up one in BelgiumAre these just in France ? If not how do you see other countries pls
Yes!! You can follow all the instructions but if you don't go right up to the barrier (within 1m we were told) it wont register that you are there!! Same applies on the way out.And you have to be right up to the barrier before it opens too.
