Hi, I'm trying to work out if our leisure battery is goosed, or I'm just missing something obvious (quite possible, since i know nothing about it). When on ehu, turning compressor fridge on (Dometic CRX50) causes voltage reading to drop from 12.6/12.7 (which is where it usually stays) to below 12 in minutes (maybe even seconds) - from this I assume ehu is not charging battery? This seems to make sense in that previous time on ehu (this was only second time, didnt use fridge before), voltage stayed around 12.5/12.4 (only used for led lights/phone charging), whereas I now think it should be higher when on ehu. Power is getting into van since sockets work and RCD trips when tested. Battery voltage is generally 12.6-12.8 and charges from main battery when driving; it also seems to retain charge OK since was used without ehu for a couple of days and seemed OK (albeit minimal usage). Previous threads have mentioned a mains charge controller but I cant seem to find anything that seems like it could be this - basically theres the rcd unit (with 3-pin plug socket next to it), a single cable seems to go from here to led display and theres nothing accessible between. LED display (which seems standard) has five buttons (one is lights, one is fridge, I guess one will be water pump (although not tried it) - no idea whast other two are but I assume unlikley to have any relation to mains charger?? Its possible battery has been allowed to run down since I think van probably sat around for a good while over winter so maybe it is done, although other than the fridge draining it almost instantly, it seems OK. Or could the fridge itself be the problem? if engine on, it stays on without draining leisure battery so my guess is probably not, Any advice welcomed...
