- Feb 13, 2025
- 1,996
- 3,283
- Designing new moho
Qwin; I used the same terminology (combine systems), that you used, to try to avoid confusion.I suspect it dates back to early caravans and 12v car battery supply hooked up. Its harder to combine systems of different voltages.
Well not quite, the voltages are never combined, with DC input AC output on an inverter.
Inverters are very inefficient. eg running a DC fridge from a DC power source, would be better than running an AC fridge from an inverted DC source.
A USB socket is only 5Vdc but that's not the point, its not a power source, just a drop down outlet.
Sure, the less you transform down the lower the losses.
I think with 48Vdc appliances, you would have limited choice.
It could get unnecessarily complicated, working with your vehicles 12Vdc system would not be as straight forward.
If you want to keep things simple, 12Vdc is the better route in my opinion.
Which inverters do you mean?
Inverters can be as much as 95% efficient and it is more efficient to move from 48V to 230V than from 12V to 230V.
Think of a domestic system, which will be storage at 48V (currently [no pun intended lol]), and inverted to the domestic voltage of 230V.
I didn't mention USB sockets because I shan't have any because they may well become obsolete in a short time.
I didn't mention 48Vdc appliances.
Why do you imagine that it would be complicated working with my vehicles 12Vdc system, when the Hab area is a separate system from the vehicle system?
I wonder whether you considered that there will need to be an inverter for the oven, microwave, aircon etc. Little difference in including the fridge /freezer in that list.
Regarding inverters and their invertion from 12v or from 48V, to 230V, I have been advised, by those who know, that 48V is the better option than 12V. More efficient than going from 12V and with cheaper components.
That's the advice I now have from those who know; not my opinion.
[edit]
I shan't be using EHU. Off-grid only.
[/end of edit]
