Scout
- Apr 4, 2009
- 3,959
- 121,329
- chic c line
- 12 years motorhoming, a lifetime of living
the drain valve castle nut on my c line came adrift from the vertical leg that operates it last week, a simple job to rectify at the time, but there is a spring at the top of the vertical leg, held by a bolt in a slot, this bolt is loose and the spring is fully extended, should the bolt be tight in the slot hold the spring compressed more, or is it correct as it is ? you can just about make out the bolt head in the top left of the pic, it has a lock nut on the far side so I dont see how it could have come loose unless iut was never tight in the first place.
