We found that too ... when we got our first PVC in 2012 I can't remember how many times we tried to knock ourselves out on it ... we stopped doing that eventually but in our current PVC we keep head butting the locker above our bed instead which isn't that high as we sleep the 'wrong way round' (ie heads where our feet should go) so it's lower than it would normally be ... still hitting it even after 2 years ... I fear we won't ever learn!It does take some getting used to the lower headroom to access the cab in our panel van conversion after having a coachbuilt.
So annoying isn't it!We found that too ... when we got our first PVC in 2012 I can't remember how many times we tried to knock ourselves out on it ... we stopped doing that eventually but in our current PVC we keep head butting the locker above our bed instead which isn't that high as we sleep the 'wrong way round' (ie heads where our feet should go) so it's lower than it would normally be ... still hitting it even after 2 years ... I fear we won't ever learn!
Daft design indeed ! I was having a similar problem with my pillow squishing the window blind, but it was a far smaller window than yours, so I don't know how much help, if any, my solution would be for you.Below is our bed layout, you are supposed to sleep with head on the right next to the window (you can see that the lights) ... daft design as you squish the blind with your pillows and can't sit up easily or comfortably as the blind surround digs in plus we like to look at the view out of the window in a morning whilst having our cuppa which we can't do if it's behind us! We therefore sleep with our heads on the left side (I've moved the lights) and it looks like quite a big bit of space underneath the locker but once the mattress topper is in place and pillows there's not much of a gap to 'slot' our heads into!
I have toyed with the idea of either getting a window put on the left side but this would still leave the window surround/squished blind problem, or alternatively alter the large locker to make it shorter ... neither are an ideal way round it though and could be costly. One other option is to get a full mattress to replace the segmented one as that at least would negate the need for the topper ... I intend to look into this to see what different it would make, even a couple of inches would make it more 'comfortable' for sitting up.
We did try that on the rear doors and side window (recommended by Ludo) to prevent the dogs damaging the blinds when on the bed and also to stop us hitting them with the duvet etc (they don't half make a noise when you do in the middle of the night!), but we found it a bit of a faff when we wanted to open/close the blinds/windows especially since our dogs like to stick their noses out of the windows ... can't keep the 'little darlings' off the bed in a morning as they sulk and don't let us have a lie in, or evening when hubby goes to bed before me ... I have to 'evict' the little monsters to get in bed myself!Daft design indeed ! I was having a similar problem with my pillow squishing the window blind, but it was a far smaller window than yours, so I don't know how much help, if any, my solution would be for you.
I used a piece of Perspex, which rests on top of the rear door release and a couple of small, self adhesive Velcro pads to retain the top. It's discrete enough to leave in place, stops the blind getting damaged, allows me a view out of the window when needed and I can still easily open and close the blind.
