break lights gone...bessacarr e435 (1 Viewer)
Dec 8, 2018
46
16
Bessacarr e435
1 year
hello peeps!
like it says.....I need to go for battery charge and water, but lights are out!
what do I need to check to see if I can fix...garages all full of customers...
connections underneath MH body look ok, so fuse or switch at brake pedal?
anything else I need to look at?
took cover off one light and all bulbs are happy there...
george
Louis
1,201
982
Anglesey
Fiat Ducato Auotrail
6 Months with motorhome(35 years tugging)
Bulbs connections, fuses, connections under van?
440
1,366
Ormskilrk
Swift Voyager 685FB
Normally the lights are on two separate circuits so if a fuse blows only one side stops working. I would start with the switch at the pedal.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Brake lights are on one fuse, what year is your bessacarr? Check the fuse first. If you have a towbar and use a trailer board or additional rear lights via the towing socket that could cause the fuse to blow depending on the year of the vehicle.
D.
9,953
17,658
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i had brake lights failed and it was the switch had slipped out of its holder. cable tied it back in place
TheBig1
17,183
41,201
The other suspect is a bad earth at the rear lights
6,565
7,429
Manchester
A class Hymer
Since the 80s
It's easy to check a switch. Pull the two wires off, and touch them together - the brake lights should go on, and they'll go off if the wires are not touching.
