Brand new avtex tv not turning on
autotrail delaware
Long time
Got new tv, plugged in when the van was in the drive at hone on ehu and worked with 12v perfectly. Now away in van off ehu, plugged in to 12v and aerial and it will not turn on, I have made sure the two on buttons on the tv are on and have tried in another 12 v socket and it will not turn on. I may have left it on standby when I packed it away at home because we had not fitted it to the bracket so am wondering if I have inadvertently drained a battery in the tv. Can’t phone avtex until tomorrow any ideas please
Thank you, I think they should be charged as we were on ehu last night but will check this
So the leisure battery says 14:3 v so supply should be good
Are all lights, pump, fridge etc working? Does another device work from the sockets you are trying the tv on? You could have blown a fuse.
Does the little light under the tv come on when plugged in. If like ours it’s underneath on the left?
Do you have a mains adaptor for it? Try it on a 230 v socket.
No, it did when was on the drive at home plugged into ehu but using 12v socket to power tv
You're still on hookup or solar as the battery voltage should be around 13.7v not 14.7v..... That's a charging voltage.
Its either power to the 12v sockets has failed (blown fuse) or the TV is faulty.
If you have a dashboard 12v socket try it in that as it should be powered from the starter battery or try something else in one of the other sockets
Upvote 1
Try another device in the 12v socket. If no power then fuse tripped. If the socket is working then make sure 12 v power is fully home in the tv and socket. As above, try it in the dashboard 12 v socket with ignition on.
