Black water stained
Luton
Coach built
8 years
Good afternoon
I’m looking for help and advice on ways to remove the dark water stained from the side of my motorhome
If you mean black streaks where water has run off the roof then Fenwick black streak remover would be a starting point.
Some say it works, others say it doesn't but worth a try.
It's going to take elbow grease anyway.
Once removed a couple of good coats of quality wax, not the wash n wax rubbish, should make it easier next time.
Maybe give the roof a good clean first - that's where the stains originated and if you don't you'll be doing it all again in a month time.
TFR (traffic film remover) from any decent motor factors does the job with very little effort but, you must use it sparingly & rinse thoroughly when its done its job, you'll also need to apply a fresh coat of decent wax as per @pappajohn instructed.
I got some black streak remover from Aldi or Lidl.... shifts the streaks REAL easy.. It was about £3
