Battery
Richardjc
Peugeot compass
Hi.
I removed my lessure battery,but still got power even when the switch is in the aux position.any ideas.
You're not on hookup are you? If not maybe someone has fitted a second leisure battery somewhere else .
Not on hook up and there is no other leisure battery fitted,I think the power must be coming from starter battery some how
As stealaway says power to what?.
Yes you probably have the cab battery selected on the control panel
I have AUX selected on control panel but still got power to all interior lights and 12v sockers
Perhaps your van has its own power supply,in the form of hamster on a wheel,or if the lights are low,perhaps just a wee mouse.:LOL:;)
There should be a big fuse (30/50A maybe) in a heavy-duty wire near the starter battery. The wire will go to the 12V distribution box, or a separate split charge relay/B2B. If you pull out that fuse, you can see if the power is coming from the starter battery. Maybe the split charge relay has failed, they can stick closed. I presume you don't have any solar panels?
solar panels?
