Battery
Tufty01
Washington
Low Profile
Newbie
Hi funsters, I'm having trouble keeping my battery topped up (engine) I've tried charging with a battery charger via Jump start points, connecting directly to the battery (just taking the negative lead off battery) Also, connected a solar panel to both jump start points and directly to battery without any joy.
It's starts no problem with a jump start though! puzzled to say the least. Any advise appreciated.
Steve
Opps............. it's a Elddis Majesic 120 (Peugeot Boxer Van)
Start with the obvious... Buy a new battery, (y)
You dont state how old the van is, how old the battery is, if you bought van new or used. All those things can be factors.
So unless you know you have an almost new van or battery and suspect a problem elsewhere, bite the bullet and splash out on the battery.
Good luck..
Hi Tonka, Yeah, it's a 2016 so I suppose the battery is pretty new!
If you leave it on charge overnight and it still won't start the engine your battery is almost certainly goosed. You could ask a garage to test it for you if you wanted to confirm.
some chargers have a recondition option maybe an option
It's all too easy for a battery to be damaged by excess discharge. You might be lucky and get away with it a couple of times, especially if it is recharged in a short time after the flattening. Recondition chargers may help too. But a lot can have happened with a 2016 battery, including neglect on a dealer's forecourt. If it's not holding a decent charge (it may show full voltage for an hour or so after a long run, but then that voltage drops even without a draw from something), time for a new battery.
Measure the voltage after a good charge and ask someone to watch the reading when you try and start?
