- Jul 6, 2009
- 2,234
- 2,818
2019 Burstner Iexo, Fiat 2.3 (150) fitted with 2, 95 amp AGM batteries. If I let the batteries run down to 80% when back on hook up the follow readings are showing on the display. Voltage 13.7, charge rate 0.0, 88% state of charge. This is after being on charge for three days. If after turning everything off I remove the main and small fuse next to the batteries. Wait a couple of minutes replace the fuses the percentage of charge will read 100%. This has been happening for sometime, the van has a Schultz EBL 630 with an 18 amp. Charger. Voltage at the batteries with two different voltmeters with everything disconnected after 2 hours is 13.6 volts. If I turn the lights on the amps will show a charge for a few seconds then drop back to zero. Cant understand why the percentage will read 100% if I remove and replace the fuse. If I keep the batteries above 95% this doesn’t happen.
