Had a Battery Master (“BM”) for three years now and since then no flat starter batteries. I understand that the BM works by the starter battery receiving a small trickle voltage from the leisure battery when the starter battery voltage drops below a preset voltage relative to the leisure battery.
Now that I have lithium batteries fitted it has been 35 days since they were fully charged and they are at 78% state of charge. From the chart of approximate voltages, the voltage of the leisure battery should be about 13.2v.
So my question is, if the leisure battery is 13.2v the voltage of a fully charged starter battery is 12.7volts, then there is still enough charge in the leisure battery to keep the starter battery topped up for some time? Presumably at some point (from the chart of approximate voltages) when the leisure batteries reach 14% state of charge the approx voltage of 12.5 v will be too low to feed the starter battery? I’ve no intention of letting the leisure batteries get to below 50% state of charge before hooking up but was just thinking about the point where the starter battery starts becoming vulnerable to being unable to start the van.
I hope I’ve articulated my question well enough. Thanks in advance.
