- Jan 16, 2014
- 790
- 1,916
- C Class, Autotrail Scout
- Oct, 2013
ANY good "smart charger" will do the same thing and better........... Some models of MH already have a 4 or 5 stage smart charger installed!!!!!The Camping and Caravan Club tested the Battery Extra before they would allow it to be advertised on their website. This is what they said. "I am happy to confirm that the unit has returned some heavily sulphated batteries to around 80% and as such we are very happy to allow your product." Caravan and Camping Club UK
Why else would anyone be interested in one?Were did the OP state he had a knackered battery? or does someone need to go to specsavers.........
You need at least 14.8v to desulfate, preferably 15v plus....14.4 will destratify the water/acid mix only.If your charging system gets up to 14.4volts it WILL "desulfator / recondition your battery. At 14.4 volts ( different voltages for AGM and GEL ) the water/acid is getting "excited" and will maintain your batteries as long as you do not abuse them. The idea is good, but any smart charger does the same thing, but better. DON'T waste your money.
so it is possibly right to assume then that you have a connection with the company advertised?In an ideal world the Battery Extra re-conditioner would not be necessary; your smart modern battery charger should be all you need. We don’t live in an ideal world.
For a start most motorhomes are fitted with leisure batteries, these are not proper deep cycle batteries but a compromise between a starting battery and deep cycle battery developed years ago when boats and campers used the same battery to start the engine and run the accessories. So a high proportion of motorhome users are not using the best battery for the job.
All lead acid batteries work best when used regularly and charged fully after every use. So if you use your vehicle all of the time and always make sure your batteries are fully charged before you use them you will get the maximum battery life. If like most people your motorhomes spends quite a bit of time not being used, or you have to use your batteries before they are fully charged you will get sulphate build up on the plates. This will increase the internal resistance of the battery and eventually lead to premature failure, and however smart your battery charger it will not be able to solve this problem. You could employ, as has been suggested, a controlled overcharge, this can be tricky to do and could cause more harm than good if your not sure what you are doing. The simple solution is to fit a Battery Extra. The technical guys at the Caravan and Camping Club tested the Battery Extra tested and found it worked. This is the link to the Battery Extra website. www.recovermybatteries.com
That is, it will remix the water and acid as the acid will settle to the bottom while water will 'float' to the top.
