BATTERIES (1 Viewer)
Jan 28, 2008
10,122
18,391
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Can someone describe how to do the drop test on my leisure batteries ive got two varta ld 90s one came with the van and the other is 4 years old added when we bought the van.I understand the principle of putting a test light on each to see if the voltage drops if i do both the batteries simultaneously but singly i would assume if one is failing the voltage will drop faster? alternately what voltage drop am i expecting in what time scale i intend to use 21watt bulbs am i right that amps will be 21 divided by 12 giving me 1.75 amps would i be better using larger bulbs? worried about heat with larger bulbs?
53,500
150,328
What you mean is a slow discharge test.
First charge the battery fully and leave it to settle for an hour then:-
For example if it's a 100a/h battery load it with a 5 amp load and run for 5 hours, this will represent a 25% discharge. (adjust load/time to suit the size of the battery)
Disconnect the load and leave to stand for at least 30 min then measure the voltage.
Repeat the test and you will have discharged the battery to 50%.
You can repeat again then it will be 75% discharged.
Apr 27, 2016
6,876
8,004
Manchester
A class Hymer
Since the 80s
Batteries are usually tested at the '20 Hour' rate, which is the load that will completely discharge it in 20 hours. To find the amps load for this test, divide the Ah capacity by 20. So, as Lenny HB says, for a 100Ah battery that's 5 amps.
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
so for a ninety amphour battery i need a 4.5 amp load so the 21watt bulbs i have will not be big enough?
could i daisy chain three bulbs to gether to get 5.25?
Nov 6, 2013
1,416
3,170
S. Ayrshire
The usual
Since the beginning
Yes, 3 QTY 21W bulbs in parallel will be close enough load
Apr 27, 2016
6,876
8,004
Manchester
A class Hymer
Since the 80s
25% of 90Ah is 22.5Ah. If the load is 5.25A, it should take 22.5/5.25 = 4.29 hours, ie 4 hr 17 min.
Stop after this time, let it settle, and measure the voltage. A new battery would be at the 75% level. If it's degraded it will be lower, so you can see how much worse it is.
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
Made my test lamp rig went to garage turned of the ehu and left the batteries to settle for an hour. Went back to van to disconnect and put on test and realised the solar was still charging so now to wait another hour
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
ok they are on test but out of curiosity i put the amp meter on the test leads one is showing 10 one is showing 9 amps i was only expecting 5.25 now i don't know what the true load is
amazing how bright 6 bulbs are neighbours will think im growing weed in there
ManTheVan
1,463
2,790
South Devon, UK
Rapido C class
Yottie convert
A techie once came out to the boat and load tested a battery for me with a meter. Interest piqued by your question and the great replies, I looked up a possible meter which might be worth adding to Santa's list? £17.24 buys you a Silverline load tester on Amazon.
For some reason the insert link function results in a blank, sorry.
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
acording to our electrical specialist these are not the right test for leisure batteries
Oct 29, 2008
5,074
5,976
West Yorkshire
Thats a low price, If I buy that and post it out there would be £2.00 left for me and the tax man to share.
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
just over 4 hours on test and one battery is at 12.2 and the other at 12 assuming my ammeter is correct the 12,2 seems about right being approx 40 amps drawn roughly half the capacity and the 12.0 is failing strangely its the unknown age battery thats holding and the 4 year one failing. Of to find some way to check my ampmeter WHAT DOES EVERYONE ELSE THINK?
53,500
150,328
Have you let them settle for half an hour without a load before measuring voltage?
53,500
150,328
Those are useless for testing a leisure battery they test CCA which is a starter battery test. There isn't anything you can buy of the shelf for testing leisure batteries.
ManTheVan
1,463
2,790
South Devon, UK
Rapido C class
Yottie convert
That explains that then. Thanks Lenny HB. To be fair, the techie was testing a starter battery for me. Shame there isn't something that will give a quick idea of the battery longevity and state, although it wouldn't be as accurate as the one you have detailed above.
mitzimad
Jan 28, 2008
10,122
18,391
Renalt burstner
12.3 and 12.17 after resting my real problem is whether i trust the ampmeter or use the expected ampage from the 3 bulbs
53,500
150,328
I think you a meter is very suspect and if you had 3 bulbs as a load I would work on 5 amps so it looks like your batteries are shot.
53,500
150,328
You can take Gels down to 20% and still get a long life they also last a lot longer 6 to 10 years plus.
Only disadvantage is they take longer to charge as they need an absorbstion phase of several hours to reach a full charge.
You do need a charger with a proper Gel profile and for best performance your solar regulator needs to have a Gel profile.
Exide and Sonnenschine are the most popular, Sonnenschine make the Exide Gels and tend to be a bit cheaper.
I have 3 x Sonnenschine GF12065Y 78a/h Gel's, 2 are 5 years old & 1 is 3½ years old still performing like new batteries.
Not come across the Photonic Universe one before but they are a reliable company and you get 10% discount if a member of the C&CC. Very cheap for the size but I don't think I would want to fit it, weighs 61.5 kg.
I would rather have 2 or 3 smaller batteries so if one does fail you are not left without power.
68c
Oct 22, 2019
1,822
2,803
Southampton
2001 Pilote 270
If want a decent meter that can read up to 100 amps these are good. I always keep one in the van.
I am considering buying a clamp on meter. One thing that worries me is how good they are at reading low DC Amps, less than 10A, which is a common requirement with automobiles. Some folk talk about wrapping several coils around rhe clamp which rather takes away any advantage in using a clamp on rather than series connected meter.
53,500
150,328
It will measure down to milliamps, I found readings vary a bit below 100ma.
