Bathroom waste pipe renewal
Scrapmullion
Burstner Ixeo Plus
I have a year 2011 Burstner Ixeo plus (from new). It is necessary to renew a leaking waste pipe, the one that drains from the swinging basin. I have disconnected at the basin end but would appreciate help on accessing the other end which is hidden behind the panelling. I suspect it is necessary to remove the plastic panelling that is behind the flexible basin water cable.. Thanks in advance.
I think its probably easiest to remove the shower screen and the back wall panel.
I have removed the shower wall on my old T660
Undo every screw you can see, its also likely to be attached with double side tape.
This one?
Have you identified where it is leaking as most of the pipe will be hidden and out of the way of being able to be damaged.
We have a 2010 Burstner Solano t725. As we go through the hab door, the shower room is immediately on the left. Our cassette door is to the left of the hab door.
We can get access to the convoluted pipe that drains the swing wash hand basin by opening the cassette door and following the inside wallskin to the left.
It's a little tight and mostly done by feel but I was able to reconnect the convoluted waste pipe when it came off after plunging the wash hand basin.
Good Luck.
