I’ve recently had a problem opening the habitation door after unlocking it using the central locking button on the dash. Basically it was jammed shut with me inside and it couldn’t even be opened by my daughter from the outside.
Eventually after many attempts to open it by setting / unsettling the CL many times when I pulled the lever and applied some pressure to the top and bottom of the door (where the shoot bolts are) it popped open. Relief!!
The system has settled down now and now after deactivating the CL on the dash I can open the hab door using 2 pulls of the lever. The first pull opens the door to a half open position (like when you don’t quite close your car door properly) and the second pull lifts the shoot bolts over the hooks allowing you to open the door. So now it’s always 2 pulls one after the other. However I seem to remember that prior to this issue with the CL I only had to pull the lever once.
So my question is how many times do you have to pull your lever to open the door? My Autograph is a 2017 model with this door lock.
