- Sep 7, 2021
- 219
- 479
- Benivan 120
- Since 2021
This is an interesting one...
First trip away in our (2021) Fiat PVC since fitting a B2B charger, and the van gives a 'Check Glow Plugs' warning when starting it if I have allowed the lithium battery to charge. The warning flashes for a few seconds, then the glow plug light flashes for about 30 seconds, then it clears.
If I block charging on the lithium battery via the App then it starts without giving the warning. This pattern seems to be 100% reliable so far.
The B2B is a Votronic 12-12-30, and is using the D+ line to control charging.
I am suspecting that the large initial current draw of the B2B charger is somehow messing with the way that the van monitors the glow plugs when starting.
Anyone else seen anything like this? I am tempted to try to put together a circuit that delays the D+ signal to the B2B by say 30 seconds.
thoughts?
cheers,
Robin
thoughts?
cheers,
Robin
