B To B charger
Sep 7, 2016
391
336
Ayr
Adria Matrix M670SL
Hi guys has anyone fitted a B to B battery charger to their Adria motorhome " if so where did you mount the charger as I have heard they heat up a bit , not much room where the leisure batteries are under the seat at the door , so just looking for some guidance if anyone has fitted one of these, I'm looking at the Vitron isolated charger, thank in advance .
May 23, 2012
354
304
Anglesey
Adria Matrix 670
I have a 2020 Matrix and was going to fit B2B charger but when my hab battery was down a bit I started the engine and was getting 50amps from the alternator which recharged it quickly. So do I still need a B2B any advice would be most welcome.
Jim
Ringleader
Jul 19, 2007
31,696
87,036
Sutton on Sea
C Class Diesel RV
Since 1988
Throwing amps in is good, but only so far. The multi stage charging B2B will caress your battery, as well as charge it about 5 x faster than your split charge relay.
Sep 29, 2019
985
2,625
Hymer Exsis
20 years
I put mine under the seat, it’s in the thread bookmarked on my signature.
You already have one if you are getting 50amps out.
You should be able to trace the cables and find it to confirm.
Jan 19, 2014
4,437
13,508
south shields
Chausson 620 welcoome
since 1990
I dont agree with that statement..
If your split charge system wiring is substantial enough..and the alternator is capable enough there is no reason why you couldn't get high current flow through a split charge system..
In fact one of the reasons for fitting a battery to battery could well be to limit current flow and protect the alternator especially at low revs when the cooling may not be sufficient..
All this made more critical by installing lithium which will take a very high current for a more prolonged period than a lead acid bank.
Andy
Sep 29, 2019
985
2,625
Hymer Exsis
20 years
Andy
I agree that you could disagree. :)
Hymer generally do thick cable and good split charging systems. Never seen more than about 25amps out of mine hence why I think there will be a B2B on the system.
I could be wrong, only way is to find the B2B or lack of.
Tombola
404
1,469
Autotrail Imala 734
12 years
thats a good amount direct via your split charger.
Jan 19, 2014
4,437
13,508
south shields
since 1990
Sorry.. re reading my post its a bit blunt..I'm afraid I have little tact..and indeed you could be right and there may well be a battery to battery charger already installed.. (y)
It's just your statement stood out when I read it..
I had a battery to battery installed and I had the split charge disabling relay wired so that I could activate it or disable it..
I wasn't doing this at high current loads but I played around with it for long enough to see that where the alternator voltage exceeded the output voltage of the battery to battery charger the split charge wiring did in fact provide a higher current to the leisure batteries than the battery to battery charger was doing when the split charge system was disabled.. if you follow that:unsure::rolleyes:
Andy.
May 23, 2012
354
304
Anglesey
Adria Matrix 670
How will it charge my battery 5 times faster when my alternator is putting 50 amps in
Trout bum
Sep 7, 2016
391
336
Ayr
Adria Matrix M670SL
Bit confusing now 🙂Most folks fulltiming seem to have fitted a BtB unit as most are wild camping and want batteries kept charged while driving, I take it vans have a split charger unit fitted as standard ? So I'm guessing when so many folk are installing a BtB it's a much better unit, it's just finding space to install it I can't put it under drivers seat I have the compressor for rear air bags there, also I'm thinking of fitting an inverter as well for off grid camping , to be honest I think it's going to be difficult to get booked on a site this year as there are more Motothomes and caravans than there has ever been due to staycation and folks not wanting to fly .
Lenny HB
27,726
46,805
On the coast in West Sussex
Hymer B678 Dynamic Line
I see 44 amps on one of my Hymers when the Gel batteries were very low.
Feb 19, 2020
179
182
North Ayrshire
Adria Matrix 670SC
Newbie
What is it you want the B2B charger to do? As it is just now On hook up or with engine running both batteries will be charging. Do you want to charge the cab battery from the hab assuming you have solar which only charges the hab battery? Battery Master would do the job in that case.
Trout bum
Sep 7, 2016
391
336
Ayr
Adria Matrix M670SL
Due to a lot more motorhome and vans being on the road campsite are going to be difficult to get booked into, so I intend to do a lot more wild camping, so want leisure batterirs well topped up when I am travelling, with a BtB charger and an inverter will have all the power I need hopefully .
Feb 19, 2020
179
182
North Ayrshire
Adria Matrix 670SC
Newbie
I don't understand what you're want the B2B to do. Your alternator will already charge your leisure battery when travelling. Am I missing something?
Tombola
404
1,469
Autotrail Imala 734
12 years
Hes looking for more ooomph,
for instance my alternator only charges mine at around 7 amps, adding the b2b gets me 37
Lenny HB
27,726
46,805
Normal charging via a split charge relay is only 15 to 25 amps with a B2B you can get 50 amps plus.
Trout bum
Sep 7, 2016
391
336
Ayr
Adria Matrix M670SL
at present leisure batteries only get a small charge with a B tB they get a lot more hence better for wild camping
West Country Motorhomes
Passionate about energy
Friendly professional service from qualified technicians
Rhino Installs
