Autowatch 695 alarm fault
1802gbrown
elddis majestic 285
My autowatch 695 rlc alarm on 2017 elddis majestic has developed a fault when trying to arm it, there are a series of beeps after the normal chirp.Is there a list of what these mean? I have checked batteries in the wireless pir and the bonnet contact and these are ok. Any ideas thanks
It usually indicates a door open. As you have checked contacts etc, that would leave the central locking contacts in the doors.
Give Autowatch a call. I've found them very helpful talking me through a problem.
batterys in hab door sensors,ie garage,hab door any external door sensor .all have their own battery.
Mine was a poor bonnet contact being pressed only by the under bonnet insulation.
I stuck a plastic disc onto the insulation where the contact touched.
Perfect now.
Same here. Easy to test, just pull the wire off the switch, make sure the wire doesn't make contact with metal & set the alarm. If it sets and stays quiet you have found the problem.....
