I decided to give the fresh water tank a much needed clean on my 2017 Autograph 79-4T. After removing the large screw cap off the top of the tank I spotted on the inside of the tank a red plug / rubber bung on the base of the tank attached to a silver chain the sort you'd have on your bathroom sink - in the 80's
. As far as I can see this must be a plug that can be removed to drain the fresh water tank as the drain tube (with a tap on it) under the van is a very small gauge and takes ages to drain.
My question is before I try and remove something that shouldn't be removed can I remove this rubber plug / bung to empty the tank?
My concern is that if I removed it I wouldn't be able to get it back in or it would need sealing / expensive trip to the dealer?
