Apple calculator (2 Viewers)
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Is it just me? Tried doing a simple calculation using the calculator that is native to I-phone and it gave way out result so tried a few others and they also give strange results e.g 40+40÷2= and it gave the result 30!
I tried to find how to tell this to Apple but they want me to pay to contact 'support' desk
Wyn
C
Chockswahay
Weird! I just did 40 + 40 ➗ 2 and got 60!
I think it see's this as 40 add (40/2) :eek:
Chris
21,054
278,743
None
10 years
I just got the same result, until I did 40+40 = and then divide by 2 and I got the right answer.
Strange.
WynandJean
WynandJean
6,670
3,303
West Midlands
Since 2010
It started out by trying to get £4.99 add £2.45 and divide by 2 which Jean was trying to do on hers. It gave 6.215!
Wyn
Mar 3, 2013
1,485
6,163
Poole
Apple calculator must use BIDMAS which would be the division before the addition. Need to press the equal sign after each part of the calculation to get the correct answer. Not a great idea on Apples part. My IPad does the same thing but my cheap school £1 calculator makes it 40 .
trekkin
332
490
Staffordshire
Rv
5 years but still learning
Mathematic priority. Without parenthesis all calculations should be done in the order mult/div/add/sub
Most processors will work this way
Feb 27, 2011
14,737
75,987
UK
Self Build
40 + 40 / 2 does = 60. I can't believe that the Apple calculator gets this right. Normally Apple try to be helpful even if it means doing things the wrong way.
If you want to include a mix of +/- and * or / then use parenthesis.
you are probably expecting the answer to be 40? If so you need to do
(40+40)/2
When you use parenthesis the calculator will do the calculations in side first then use this result in the rest of the calculation. Otherwise multiply and divide take priority.
C
Chockswahay
(40+40)/2
Ha ha, I was about to say 'thank goodness for calculators!' then I realised we wouldn't have this thread if it was that easy :rolleyes:
43,329
49,444
Just done the same calc on my old none-smart, none android samsung phone.......same result 40+40÷2=60
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
So if you turn your android on its side you get a load more controls including parwthesis. If you want to mix multiplication or division with addition or subtraction you need these
All computer based calculator s use a calculation order.
Dec 27, 2014
967
3,361
We're all out iPhones made in Greece !
No wonder they are up the creek !
MattR
4,104
38,880
Beds
Panel van
Years
Senior moment Matty? :ROFLMAO:
Not this time, just realised that the reasoning for the answer had been given a couple of times previously. I'll save my senior moments for .... what was I writing?
Minxy
32,651
66,545
E Yorks
Carthago Compactline
mjltigger
1,619
2,672
Trowbridge
Same result on my Android phone ... weird!
Till you do it right.
