Jeffers_S13
- Aug 1, 2019
- 20
- 4
- 2004 Apache 700SE
- I'm a newbie
I'm fairly sure my '54 Apache 700SE has Alko extensions on the back of the fiat chassis after a post that someone made suggesting that if the parts are galvanised then it's Alko. They look like they're welded on (the area that was dressed before welding looks like it had no sort of protection applied so there is some heavy surface rust.
It also has rear stay frame fitted, unsure whether this was a factory option or if someone has had them added at a later date? either way it was also either untreated when installed or the paint was very poor as it's rusted quite bad, it's also twisted as though they've been clouted on something, presumably because the back swung around and hit maybe a kerb (?!).
Forgetting that the stays are there (I may remove or modify them to accomodate a tow bar) but does this mean an 'Alko' towbar could fit? what makes a tow bar an 'Alko' tow bar? is it the width between the rails or that it makes use of mounting holes in the Alko chassis?
Are the Alko extensions the same shape/design as the rear ends of a full Alko chassis?
Is there anyone in the LE postcode area that has a 700SE of the same era as mine with a towbar fitted that I could come and examine/take pics of?
