Jeffers_S13
- Aug 1, 2019
- 20
- 4
- 2004 Apache 700SE
- I'm a newbie
Hello All, newbie here, I'm looking at a low mileage (35k) but old (2003) 700SE at the moment. It's priced at £19k but it needs a bit of TLC which I am capable of carrying out being pretty spanner friendly, some corrosion on the front lower arms and front subframe, brake lines don't look great and couple of sticky calipers, plus a few small cosmetic jobs but one thing that's obviously worrying me is damp.
It smells fine inside and I inspected every single corner of it inside and found no trace. However when I inspected the roof (I didn't walk on it!, I used a step ladder to the side) the plastic upper surface, when pressed lightly, is flexing. There is a small strip of duck tape covering what I suspect is probably a small hole/damage approx above the shower area, it looks like it's been there for some time as it's started to go crusty, you know how old gaffer tape does. Anyway the plastic is flexible over an area as far as I could reach from the side. It feels like only the upper sheet is flexing which I assume is meant to be bonded to something beneath. Whatever is beneath felt structurally sound.
I want someone to tell me this is 'normal' but I suspect it isn't...
Obviously I'd like to get a good deal on it due to the mechanical and cosmetic issues that need sorting but does this felxing roof mean I should walk away? or would it have to be an exceptional 'deal'? How much would a specialist charge to peel it back and sort it out? is it DIY level work? what will I find beneath? a whole load of rotting plywood?
Thanks for the help in advance!
James
James
