Apparently thec D+ Or ignition trigger needs to go to a different terminal than they show in the installation instructionsCan’t view the video at the moment - what’s the issue?
We have a BB1230 working fine on a euro 6 Relay.
We bought ours from a distributor on EBay so might not have been latest stockI can’t recall the details, but there was a flyer and/or a sticker on the box when I got mine with different instructions to the manual specifically about the D+ connection. I guess they still haven’t updated the instructions!
Should really make any difference with a Ducato as Fiat's supplied for conversion
No need John (thank you)Just checked and mine came with a loose sheet which mentions this for Euro 6. It's configuration 3.
I can scan the complete sheet tomorrow if you like Robert and I can send it to you as a pdf if you want a copy.
I wonder whether Fiat will have to turn the smart alternator on to achieve Euro VI D?Should really make any difference with a Ducato as Fiat's supplied for conversion don't have a smart alternator.
Mercs do so it will be relevant for them.
The B2B charger will only charge your leisure batteries when the engine is running.I’m trying very hard to understand the technical bits on this thread and wondered if you could help. We have a Fiat Ducato 2019, a Euro 6 engine. We are having problems with the 12 volt and wondered if the Stirling B2B 1260 could be a better solution than carrying a Generator and petrol around, which we dont want to do. Could you tell me if it would help charge a disability scooter? We have an invertor already fitted. Another question is, the video seems to show a lot of noise from the Stirling B2B, is this the case?
How old are the batteries?The leisure batteries are not holding their charge, we have 2 80 gel batteries and a 120 solar panel, but as soon as the media system is turned on the batteries drain - orange from full green within 35 minutes when the TV is on!
Id ask whoever fitted them if they’re connected to a split charge relay which should charge them whilst driving3 months old, we had them fitted on our new Camper. It is a Carthago Malibu, we wondered if they had fitted the gel batteries and not connected ‘something’. We had a similar system on our Globecar and it was superb.
I’m stumped !They are charged when driving, its the only time the control panel shows both batteries as being full. They are not full on solar, with nothing turned on, and they do not show as being fully charged when we are on 240! Crazy.
Hi GeoffI have not really got my head around how your B2B is wired.
We have an older model and have wired it direct to the batteries and works fine, not through any other system. Even Sterrlig admit they cannot make it compatible with Electroblok.
So, in extremis, just wire it direct to the batteries. Because it is difficult to get two control systems to talk to each other if they do not have the same technology.
Geoff
Ginny, we have had the B2B fitted for 5 years now and very pleased with results. Not sure about the above posts as not same model as ours, but I'm sure owners of you van will advise. We can leave van running static for about 20 mins (on tick over) and batteries fully charged or if Dawn wants to use hairdryer at full heat just leave vsn on tick over and batteries can handle draw from batteries.The leisure batteries are not holding their charge, we have 2 80 gel batteries and a 120 solar panel, but as soon as the media system is turned on the batteries drain - orange from full green within 35 minutes when the TV is on!
Ginny, how long have you been parked up (after driving how far)?, what else is using the batteries? - a short 1,2,3 hour drive will not full charge 2 x batteries. park up for 2 or 3 days in UK sun will not charge your batteries. If in EHU your system should change over to supplying 12volt across the van via charging unit whilst charging (in most cases slowly) the batteries.The leisure batteries are not holding their charge, we have 2 80 gel batteries and a 120 solar panel, but as soon as the media system is turned on the batteries drain - orange from full green within 35 minutes when the TV is on!
If the EHU is doing this take the van back and ask why........
Is that a windup.Wouldn't it be brilliant if all our devices and toys ran by clockwork?
JJ
