- Apr 6, 2019
- 6,293
- 13,069
- RV
- FourWinds Windsport 6.8L V10
Me thinks it’s not anti bacterial
Is there an executive summary for those of us with dyslexia or other people who hate reading ?This is an account of how I fitted a filter. It has worked well since being fitted.
No, only the pump activated by pressure.That looks a good offer including the tap as well?? just one reservation I don’t know if the tap would work if you have a system with micro switch in taps??
dead link?We use a filter system by a german company www.wm-aquatech.de. There is a UK dealer, Mirrorguard. They produce various filters including a tank cleaner. Procedure is to clean tank, fill with water via the filter. If you use one of the silver pads in the tank water will remain fresh and tasty for 6 months. Filter removes everything, all known pathagens etc. They reckon you could even filter pond and river water - not got the courage to try that. Not bought bottled water for over 12 months. Water tastes great.
Can't see that it is any better than the one i linked too? Here is the data sheet,![]()
Kitchen Water Filters for Homes and Offices
Undersink Drinking water filters for your Home Kitchen. Get clean healthy water on tap all day every day. No more bottled water. This is a 10 inch / 10" house unitwww.uk-water-filters.co.uk
This is the one we have, bit more expensive than that one but the replacement filters are cheaper.
The Pozzani one?I have one fitted and it works well, I replace the filter every year regardless of use,
Very useful. I also contracted Giardiasis from (I’m fairly sure) a contaminated water source in Spain. Not pleasant and can be difficult to get rid of requiring several courses of high dose antibiotics which is as unpleasant as the disease. Careful where you get your water from and don’t skimp on filter quality!This is an account of how I fitted a filter. It has worked well since being fitted.
I didn't publish an account on here because everyone's system is so different. It wasn't hard to fit on our vehicle as access to the water system and pump is very easy - we just open the back doors.Is there an executive summary for those of us with dyslexia or other people who hate reading ?
In my camper I use a Nature Pure system that will filter down to 0.1 microns absolute, expensive at £600 but very good.
But, when my filters are gone I will be binning it due to the dishonesty in distribution by the manufacture, exposed on MHFun
You shouldn’t have to double check what your given when your buying products that claim to remove Virus’s and Bateria
Wasn't trying to claim it is, they do the same job. I'm just showing the one we use as an alternative.Can't see that it is any better than the one i linked too? Here is the data sheet,
<Broken link removed>
We used to have one of these fitted in our old house, does make a huge difference to the taste of the water, it does exactly what they say and if you get the Hard Water filter it does remove most of the scale. We currently have the same one as Nixdorfer has, again with the anti scale filter option, does about the same level of taste improvement and scale reduction appears to be about the same but as we are now in a totally different region that's just a guestimate. Not sure where Nixdorfer is getting his replacement cartridges from but the Pozzani filters are considerably cheaper, £11.50 compared to almost £30 for the anti scale version from UK Water Filters.
Yes, that was the one in my opening thread. only 1micron filter though, 0.5micron is advised to filter certain micro-organisms. Not that we wild camp as such but checking what others have used.Have this fitted in our motor home , easy to fit and no problems so far
Patrick
