Anyone help electrical problem (1 Viewer)
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Thank you... we are on ehu but fridge started beeping- no power. Did not have anything but fridge on .have tried different ehu points no avail. 12 volt working. Have switched all fuses on and off in cupboard head door as thought they were the tripsswitches but can’t find anything else wrong - Hymer b544 - any hints gratefully received ...we have 2 Varna batteries under passenger seat both look new / ok.......
Dec 6, 2011
11,607
25,486
South Wales
Coach built Adria
yep i agree with above, 1 step at a time.
1, is there mains into the van?
no...... check mains consumer unit,...... check ehu is plugged firmly into van...... check back at ehu post has not tripped .......... check ehu cable and socket wiring.
yes..... check sockets are working, if yes .... there is usually a main fridge fuse find it and check it.
Kirsten
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Leisure batter workin yes showing 13+ amps yes have 12 v supply.... no power into van as little diagram of van shows no ehu . 12 v socket works . There is a50 amp fuse in the 2 battery thing under the seat -also a 2 amp fuse... we don’t have a spare 50 amp fuse .....
Kirsten
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Phill D we have tried all you said thank you ..David G 58 also thanks... going to try plugging it in again checking connectors on the bit we plug into van and into the ehu... no spare ehu. And no other uk people’s on the site here ....
Dec 6, 2011
11,607
25,486
South Wales
Coach built Adria
so no EHU coming into van. so no 240v socket working.
so at least you know to trace back from the ehu consumer unit in the van to the ehu post.
Dec 6, 2011
11,607
25,486
South Wales
Coach built Adria
sounds as if it was an external power loss that affected you. assuming all was working at that plug in and it suddenly happened.
OldCodger
854
201,460
Surrey, UK
Carthago I 143 LE
Since 2016
We get occasional fat finger problems on our fridge - on the fridge controls is the A option selected. I have been known to catch the battery icon and everything gets warm?
Feb 26, 2012
528
368
coach
Motorhome since 2006 (caravanning 38yrs)
Suggest that you check the hookup post.
If there is a button press switch next to where you plug in, is necessary to turn the plug after you have pushed it in to make a connection. The button needs to be pressed to release the plug when you unhook.
Kirsten
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Thank you everyone- we have plugged it in to several other ehu posts to no avail .. wondering if our ehu lead has suddenly died - it is v old . Sarah has gone to ask at reception if they have a spare one . Meanwhile I am attempting to dismantle the lead that goes into the van - does it just pull apart ? In hope the wires may have come loose from that. We have gas and solar so not yet a full blown disaster ....
Dec 12, 2010
5,420
21,629
Cumbria
If it's the normal blue plug and sockets, they sometimes have a couple of screws that clamp the two halves together, or have a couple of screws that you access end on, where the pins are.
Badknee
7,408
413,381
notloB
Vantage Neo
Living the dream.
If something similar to this is on the post your plugged into the switch needs to be up. Don’t worry about the button, it’s to test the RCD. It would help if there’s any Brits or English speakers to see if you can borrow a lead from them to test, yours might be faulty.
Good luck 👍
Kirsten
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Taken out screws in the clamp help German woman also just said they have no power either it is the bloody site ehu I fear and we have ransacked van to get tools - destroyed hook up maybe 😡😡😡😡I did ask everyone else on the same relay they said they were ok !,,
Badknee
7,408
413,381
notloB
Vantage Neo
Living the dream.
Ok so the connectors.
our old ones you take this screw out.
And the newer ones these two screws. All will be clearer when you can see the wires.
Kirsten
Kirsten
838
3,414
Stratford on Avon
Hymer B544
Eek.. Paul I think ours is older than the ‘ older one’ might invest in new one. Tomorrow. Ours has a screw hinge thing holding the top n bottom together then it turned but did not come apart. Hastily re fixed it- maybe .
Badknee
7,408
413,381
notloB
Vantage Neo
Living the dream.
Yes perhaps its time for a new one :doh::rofl:
Mar 30, 2019
1,089
1,380
East Sussex
Trigano Tribute
Since 2017
I would recommend you get a plug tester, there not mega money so you can plug it into your van socket.
This will check your supply and depending on which one you get whether the polarity is correct also.
Dec 6, 2011
11,607
25,486
South Wales
Coach built Adria
i have one of these and for £10 its a great piece of kit.
switch it on touch the cable / socket or whatever with it and it will beep if there is power. simples!!
i also carry a polarity tester.
Apr 27, 2016
6,879
8,010
Manchester
A class Hymer
Since the 80s
Agreed, a socket tester is easy to use and cheap to buy.
Also useful is an adaptor from Blue plug to 13A UK socket. You can plug it into the hookup post and test with a socket tester. You can plug into the end of your hookup cable to test the cable is OK. With the socket tester and adaptor you can quickly home in on where the fault is
Edit: Sorry, pointless advice, these two things are impossible to buy outside the UK.
OldCodger
854
201,460
Surrey, UK
Carthago I 143 LE
Since 2016
But good advice for the tool kit before you go!
