- Apr 13, 2012
- 5,544
- 18,775
- Mobilvetta Euroyacht
- 1996, then break 'til 2011
Years ago I was driving in Mallorca in my Mk 3 Cortina, turned down a side street and could hear my engine bearings 'picking up'. I immediately switched the car off to prevent the motor destroying itself - the hexagon oil pump drive had sheared. A local mechanic 'knew' what it was and fixed it with a cut-down allen key - no damage to the engine
A month ago my old V8 Jag suddenly lost all its water just as I was getting to work - you couldn't top it up, the water went straight through. I had recently been to Spain and back in it. If it had happened on the open road it would have been too late to stop the engine being destroyed. Turns out that there was a 2" long split in a rubber hose under the inlet manifold in the vee - impossible to see even with a camera. After the manifold was removed and new hose fitted everything back to normal - phew !
All done by a local independent Jag repairer - cost- £200 - bargain !
Any other lucky breakdowns?
