Angles mort
Portland
Conwy
C class
20 years
I was looking at a post earlier today for these and saw some markers that attached with suckers, Try as I might i cannot find that thread again so, does any Funster know where I can get these??
Loads on eBay. Search suckers with screw fixing.
<Broken link removed>
Be warned Derek, the potage is hefty. Im waiting to see if I need them, could be breathalyser s again.
On a site in Brittany with 14 French motorhome
At least 10 are over 3.5 tonne.Not one with angles most stickers on.Same on an Aire last night.BUSBY.
Reminds me of the neighbours truck he uses in Europe.I spotted one of these on the back wall of the tractor unit.
I said "what's that all about"
he replied "those bikes get everywhere"
Be aware that the ones with suckers are intended for sticking on the inside of a window, they are not designed for use externally and will likely fall off.
Have you looked closely.
French motorhomes seem to have helium in their tyres which magically reduce their gross from 4tonnes to 3.5
Following a very instructive conversation with a fellow caping cariste Ive decided to capitulate and fit my stickers. By now I must have seen hundreds of motorhomes and nearly all of them didnt have the sticker s apart from the ones that are clearly well over ( which is us) with tag axles or obviously class 3. Most ( and I mean 99%) of the ones that we would consider in the 3500+ group didn't have them. Although there were 2 identical rapido 8096 DF both from the same region and obviously together where one did and the other didn't - go figure??.
My new opinion is that if you obviously are 3/4 then you need stickers and if you can get away with arguing classe 2 then you probably dont.
Another update. I'm currently on le crotoy. Must be 80/90 mhs on here. 3 including us with stickers. The only french one is pilote tag. No rush if your only on 4 wheels.
