Ammeter fitting for solar panel
South Wales
s
HELP! Ammeter fitting for solar panel
hi all, the brains stopped working so i need some help from you solar / 12v experts :Blush:
my main display panel / control panel does not show ( as far as i can tell ) when my solar panel is charging. i.e it does not show any charge amperage. ( could be because its in 1 amp divisions so any charge below 1 amp is not shown ).
however when i put a multi meter across the cables from the Solar panel i record a voltage ( dependent on sun levels ).
so i am considering fitting a separate ammeter for the solar panel.
can i wire it as per the attached sketch? i dont want to mess with the cabling from the solar regulator to the electro bloc as they are in a purpose made up harness.
any ideas?
According to your sketch, you are using a Schaudt LR1218 regulator connected to a Shchaudt Electrobloc. That arrangement should show you the solar charge on the motorhome's display panel. Did you fit it yourself and if so, are you certain you used the appropriate wiring harness to match the particular EBL that is fitted?
If it was fitted by an installer, I should ask them why it is not working. Otherwise, you could talk to Steve at Aire & Sun - he understands these installations (and fitted mine). Alternatively, contact Udo Lang at Schaudt who speaks good English and is very helpful.
http://www.aireandsun.co.uk/index.php
Udo Lang <Udo.Lang@schaudt-gmbh.de>
p.s. there is some useful info on the A&S website, and I have the LR1218 installation and usage instructions if that can help.
many thanks, you are correct it should show on the panel. it may just be my batteries have not needed any more than 1 amp charge so nothing shown on panel.
i did fit it myself and i am 99.9% sure i used the correct harness.
but thanks for the advice and links i will follow that up.
cheers:thumb:
hi again Philip can you check the web address for aire and sun i cant seem to get to their site.
cheers
Phill
Phil,
When its next sunny try putting a load on the batteries. Fans, lights etc and then check for input current.
Phil,
thought that as a last resort i would disconnect my ehu ( i am lucky enough to be able to have one in my drive , and that might be the problem. i.e. solar never gets chance to present a charge :Doh: ) and run a few things , TV etc to put some load on for half hour then see what happens.
might have to wait a few days though at moment:Rofl1:
cheers.
Phil,
you beat me to it :Sad:
the panel will supply whatever is running until the current needed is higher than the panel can supply and then starts to draw on the batteries for any more current needed.
I dont think it will work as in your sketch as the voltage from the panel to the controller, in good sun, should be around 17volts with a lower amperage than that shown on the controllers output side.
as the controller decreases voltage to 12v (nominal) the amperage should increase slightly.
as an example.....a 230v supply giving 25amps is the equivalent to a 110volt supply giving 50 amps
I upgraded my solar system exactly like yourself. I then had to go into my vans display with an installer access code to enable the display to give me a readout of the solar ampage. Without configuring the display panel my solar shaudt regulator and the shaudt electroblok would still have put current into my batteries but alas no readout.
I belief different manufacturers have different codes for their induvidual displays. Do a google search. Or contact your supplier/main dealership.
The system works great for me, good luck.
Dai
Volts, Amps or Sunbeams it is well worth monitoring the goings on in your solar circuit. As my charge controller doesn't show voltage I do it with a plug-in LED voltmeter inserted into a socket in the leisure battery circuit.
About ten days ago I noticed the voltage wasn't rising on the odd occasions when the sun came out, so I double-checked my solar wiring and found the positive cable had pulled out of its battery connector, but beneath an insulating sleeve so the break was invisible. Without the voltage meter I'd have been oblivious of the problem until the battery went flat.
cheers
Phill
Sorry for the delay - just got back and checked the website and it will not load for me either. I have looked at Companies House and Aire & Sun appear to be trading.
Perhaps the website is temporarily off-line. Here is the phone number (correct in 2011)
01434 230580
01434 230580
sorted, did not need any intervention from me only " Patience ! :Doh: discharged the hab battery with a decent load for a couple of hours and bingo .... showing a solar charge :thumb: Woohoo:Rofl1:
Glad it is working properly. I often think there is not much charge going in on a sunny day until I check the battery condition to find they are already fully charged. I guess it's because the sun gets up before I do! :Cool:
