- Jun 21, 2018
- 504
- 1,651
- Auto Trail Comanche
- Since 2010
Unless the wheels are hanging with no load on the axle, the grease cannot get to the parts under load and therefore the important bits.Auto trail motorhome on alko chassis with twin rear axles , on applying grease via the nipples underneath on one the grease can be seen coming out at the end of the axle tube next to the swinging arm is this normal or is the axle in need of replacement/repair
Yep, 5-6 pumps any more and you can pop the seal out. Sounds like that may have happened.I believe ALKO recommend X number of pumps on a manual grease gun for each nipple.
It shouldn't leak out the end, it has a rubber oil seal.
Yes used my HPC hydraulics, with wooden blocks under the wheels, with a 1/2 inch gap (you never know) so no load on rear axles. 4 to 5 pumps like you say a doddle.Another advantage of HPC hydraulic jacking system (other inferior systems are available ) greasing AlKo axle is a doddle.
As it appears from various sources that the grease should not come out does it not cause you any concern that it has on yours, how long have you been running the van since it first came out?Make sure you jack it up to grease, yes ours came out, you know you have it in there then. Bob.
diy'er to fit them themselveshe went to great lengths to explain with detailed measurements how easy it is for a competent
The idea is to put 2 grease nipples at each end of the axle by drilling a 5mm hole and cutting thread for new grease nipple the new nipples do not have to be on the underside like they are originally they can be front rear or top whichever is the easiest to reach with the grease gun. the axle is about 6mm thick. drill through this then slowly keep drilling another 2.5mm checking till you get a yellow shaving on the end of the drill bit.
The first hole should be drilled 50mm from the end of the axle tube, that is the end that shows on the outside of the chassis and the second one 260mm from the same end. Thread the holes and screw in the nipples
If you watch this video the above is part of what they are doing
I am sure that if you wanted it from the horses mouth the man from Fraser brown would be only too happy to talk to you
