WESTY66
- Jun 17, 2017
- 8,051
- 23,234
- Carthago Chic C-Line
- All the gear, and no idea!
I have done, still trips.I’d swap the EHU cable
Is there a heat only setting for use on gas that you could try? Ours is the older style manual slide controls, giving us 3 x heating options on either gas or EHU.It appears I’m getting hot water on gas but no heating although the pump circulator sign is on![]()
I think it’s the red at the post.What is tripping the RCD or MCB?
Thanks, but heading north today, up to Rothenburg ob der Tauber.Nightmare for you. Are you in a position to get down to Carthago City
Anfahrt zu Carthago-City
Adresse:
Carthago Reisemobilbau GmbH Carthago Ring 1 (Unterrauhen) 88326 Aulendorf
Koordinaten:
N47° 56’ 22’’ E09° 39’
Its to your South.
If they will not sort you out they may get you into a local dealer
The heating must surely work on gas only WESTY66, as that is independent of the EHU, only needing 12v for the igniter. Could it be the controller that is at fault.I have hot water just no heat and I’ve could really do with it this morning!
If you have hot water the boiler is working because you can't have hot water without the glycol that heats it getting hot, do you know where your pump is? top of the tank in the expansion bottle or near the boiler as you need to make sure it is working, the pump symbol on the panel tells you only that the system is telling it to work.I have hot water just no heat and I’ve could really do with it this morning!
Thanks Richard, plenty in.Have you checked the heating fluid level?
You should have a small header tank where, with a bright torch, you can see the fluid level.
On our C-Line the header is in a small head height locker over the side seat/ pull up tv.
There should be about an inch/ inch and a half of fluid visible.
If it’s low you can, very carefully, top it up by unscrewing the plastic cap.
Only add very small amounts at a time of Alde fluid or suitable antifreeze mix.
Best of luck.
Richard.
PS. Most decent motorhome dealers will stock it.
The pump is usually mounted in front of the boiler.That's well enough hiddenis the pump on top of that tank?
