funflair
So have you ever tripped the sites electric hook up, bad enough when you have to go out in the rain and reset it yourself but even worse if you have to go find the warden and explain your predicament, especially in France.
The scenario is as follows, 6A electric and Alde heating on 1kw so taking just over 4A, wife switches on low wattage hair dryer and "click" the power goes off as you have gone over the 6A.
The solution assuming you have is of course to always remember to turn off the heating well that isn't going to happen so a better option is to let the Alde system do it itself by way off a load monitor, yes you have to have the Alde heating in the first place.
What does the load monitor do? well it does exactly what it says on the packet, it monitors the electrical load coming into the van and cuts back the Alde boiler as required by other demand, simples.
All it is is a "hall effect sensor" that the 240v live cable has to pass through before it goes to any consumer points, "this means disconnecting and then reconnecting a mains 240v cable so if you don't feel competent don't do it" the other end is just a plug that goes into the boiler and then it all talks to the control panel.
So you have to work out which is the main incoming live cable to fit the sensor, all systems will be different so you need to work this out yourself but just to make you laugh, yes all the power was switched off mains and inverter, I was messing about in the wires and there was a "click" and a 'flash" and boy did I jump
I had touched the battery powered LED at the top of the locker!! not only that but I did it twice more and still jumped.
Thanks to Michael sallylillian for telling me there is a big access hole behind the consumer units to route the cable, I then spend half an our trying to route it through the wrong hole anyway it's in now.
Sensor in place and "into the void" at the back to reappear near the boiler hopefully
TBC
TBC
