Spawn_e_git
Hi.
Burstner motorhome has Alde 3010 heating system with the old manual controller with the temp dial and three slider switches.
The circulation pump is not being turned on.
The alde system has 12v supply and you can hear the relays switching when you select heating or hot water and also the three different power settings.
There are two outputs for pumps, one for 24v and one for 240v but they are both connected together so I assume the 240v system is not part of this setup as the system has worked perfect until now.
The two removable fuses and the soldered fuse have been tested and are ok.
The hot water is working ok.
The thermostat is right up but still not pump.
the system has the stirred pump in the header tanks bit there is also what appears to be a pump right next to the heater but this is not even plugged in. this pump is connected into the heating pipes that go out to the radiators.
It seems that either the controller board is knackered or the thermostat part of the controller panel is knackered.
Any ideas and does anyone have a circuit diagram of the system?
