Brilliant thanks, just going to get re gassed or what ever they doKnob on the right push in the top button, knob in the centre rotate to give air both top and bottom,
Fan speed to max then adjust as necessary, Knob to the left to fully cold,
Don’t forget you should use your aircon all year round, you can use it with heat as a dehumidifier ,
That doesn't tend to work here & it certainly never worked for me in the Uk late last year. I tried to not use the a/c & use the heating but it just became exceedingly dangerous as the screen would mist & run with water within seconds. Even using the a/c you couldn't drive off straight away as it just couldn't sope with the amount of moisture. I wasn't able to stop using the a/c to keep screen clear in the mornings until I got down to the Pyrennee's last December.
