Hi all you knowledgeable people ,the Daughter is looking at buying a motorhome and has seen one with an MOT till July 2021 but the advisories are
- Offside Rear Brakes imbalanced requirements only just met. It would appear that the braking system requires adjustment or repair. (1.2.1 (b) (i))
- Vehicle structure is corroded but structural rigidity is not significantly reduced (6.1.1 (c) (i))
- Nearside Front Wheel bearing has slight play (5.1.3 (a) (i))
- Offside Front Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
- is this really bad and expensive to put right or should she walk away . Her budget is only £16000
