That's true, and in addition there's the amps drawn from each battery to consider. For 100 amps into the inverter, ideally you should have 500Ah battery capacity. You could push it and use half of that, 250Ah, but even that means at least two batteries. Most batteries are around 100 to 120Ah.If you only have a single battery I would be thinking about buying at least one more.
A 1200 watt inverter will draw slightly more than 100amps.... 15 minutes use with a single 100ah battery is 50% of your usable battery reserve gone.
Didn’t realise that!As I can't afford LiFePO4, I use 629 truck batteries. These make excellent cheap leisure batteries at around the 170-200Ah mark, as they're not marked up for being "leisure".
