Adria Vision shock absorbers
North Wales
A Class Adria Vision
Since 2016
Anyone had to replace their rear Al-ko shocks? If so, what did you replace them with. Mine are needing to be replaced but I can’t find which ones are compatible. Any ideas gratefully received.
If you look closely they should have numbers stamped on them, usually near the bottom.
They are unlikely to be made by alko.
Your best bet is to find the numbers,then if a google search doesn't help, take one of the shocks to a good motor factors who should be able to supply them.
