Hi Folks,
I have previously mentioned inability to switch off water pump from my Adria Compact panel. I intended sending LT313 control panel to Apuljack for test / repair, but when trying to pull them off, terminal blocks seemed tight. So rather than risk damage, I decided to ask the experienced.
I am attaching photos of what I found.
Perhaps the corrosion is causing the problem, and panel itself is actually Ok ?
So my pride and joy Adria Compact, bought in Autumn partly on the strength of a seemingly faultless and recent Habcheck, obviously has moisture dripping onto the LT313 terminals from an aperture higher behind the boarding.
Very disappointing, but compared to the modifications Doc made to my meds this week, perhaps not my biggest problem !!
Have you brainboxes any advice how to separate the connectors to remove the panel ?
Can I use WD40 ?
the black plastic terminal blocks appear to be one unit, but perhaps they divide, leaving part of the block remaining on the PCB ?
- obviously, v.important to know where they separate before applying force . . . .
_
Hi Folks,
Can I use WD40 ?
_
