I currently have a 175watt panel supplied by Bimble solar about 5 years ago. This was an ex-solar farm panel. Its currently controlled by a Epever 20watt mppt controller. This all works well and I don't want to mess with it if I can help it.
I would like to add more panels and have found a couple of Renogy ones that will fit the limited spaces left on the roof. They are an 80watt and a 50watt, both have similar outputs, voltages, etc.
My thoughts are to connect these to a new dual output mppt controller so that my starter battery gets some charge as well. My problem is that I don't know if the new panels will play well with the old one.
Should I just add in the new panels and controller as a separate system and keep the old panel and its controller working as currently? If I do this will both controllers work well together? Both would be connected directly to the hab batteries, nothing going through any built in van controller. Thoughts?
