Adding additional step to Adria Matrix 670SLT - any advice or tips more than welcome please
MisterB
Essex
Adria 670 SLT
As the title suggests, I am looking to add an additional slide out or pull down step to our Adria.
Having looked underneath, I can see where it might bolt to the chassis at the back of the step, but nowhere obvious to fit the front support/fixing - there is a possibility of fixing it to what appears to be a drop down metal plate, but I'm open to suggestions or ideas, especially if you've had one fitted or your Adria came with one fitted. Photographs would be brilliant to give me an idea. The current step doesn't appear to be strong enough to suspend an additional step which would cantilever underneath and fitting a checkerplate supporting plate doesn't seem to be right way to do it.
All help, suggestions, advice is more than welcome.
hi, i think you will have to make a cantilever type bracket to fit to the main chassis and then protrude out under the current bottom step then mount a Thule sliding step on it.
