Adding a movement sensor to awning light (security) (1 Viewer)
Ridgeway
3,532
5,746
Lausanne
NiBi Arto 85E
Since 2012
Just wondered if it would A) make sense and B) be possible to add a movement sensor to an awning light ? My thinking is that if you could use the lighting with a 3 position switch, off, on and sensor then in the later you could leave it on during the night and the light would come on if anyone walked under your awning ie a security deterrent (we put out bikes there each night) I added the long LED strips that really light up the awning area really well so i think if these came on it would deter someone from spending any time in that area...
What do you reckon ?
ambulancekidd
Sep 23, 2014
10,073
28,065
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Or stick a few LEDs into one of these?
Ridgeway
Ridgeway
3,532
5,746
Lausanne
NiBi Arto 85E
Since 2012
You'll soon make friends with the people in the next van if that's coming on during the night
Yep if i stop some toe wrag from knicking stuff.
As the LEDs are under the awning the light spill isn't too bad although they are chuffing bright:D2
haganap
12,595
25,259
planet earth
Carthago C Tourer
I'm an oldbie MH number 9
great idea(y)
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Biggest problem with a security light is animals will set it off as well ok in your driveway or garden but on a campsite or aire is probably asking for trouble.
An external sensor rigged to an internal light might save a few problems with neighbours but every animal that goes past will probably set it off
Ridgeway
Ridgeway
3,532
5,746
Lausanne
NiBi Arto 85E
Since 2012
It's certainly a potential issue however i was hoping that with correct sensor positioning, correct sensitivity adjustment and then perhaps masking off some part of the sensor that this could be overcome ie really have the sensor focused on the risk area and not just any where outside, to be tested though.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Maybe changing light colour from white light to red using a cover to change colour output would work
scotjimland
1,437
5,205
UK
Timberland
I had one fitted to my RV, just a single wall light and battery operated, so no wiring.. it was very useful when returning at night
Plenty of choice of 12v PIR motion detector sensors on eBay .. just an example
stray animals setting it off.. ?
they generally have sensitivity adjustment, besides, not many stray animals on sites and if wilding it won't matter if it goes off.
11,841
16,238
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I had one of these on a caravan 20+ years ago with a 3 position switch inside the van. It caused no problem on site & switched on when anyone was within a couple of metres of it. The problem was forgetting to switch it off when travelling at night - it would flash pedestrians on the pavement as I passed them. If you Google sensor awning lights there are plenty of options.
