We went mad and spent just over 4 times the above cost for a 120ah Lithium Battery, but we did save 13kg weight ...I currently have one 95ah agm battery in my MH. This is the make and model. Theres room to fit a 2nd one so do I mirror the current battery and buy a duplicate? Its quite an expensive battery so are there cheaper alternatives or is it best to stick with a 2nd one to match the current one? Thanks
Measure up?We went mad and spent just over 4 times the above cost for a 120ah Lithium Battery, but we did save 13kg weight ...
Shame that yours is 95ah and AGM, because I've got the original [brand new in mid April] Banner 100ah lead acid battery that I want to get rid of and you're not a million miles away from me!
Steve
Lenny HB will answer, I hope! IIRC, the advice is to use the same type and rating of batteries, but the technical reason is beyond my verylimited knowledgeMeasure up?
Why can you not mix AGM and LA batteries???
Cheers James
So another option could be to just let it be and use it until it dies, then swap it to 2 x lead acid ones rather than keep forking out on the more expensive AGMsI to have been advice that AGM are not good for leisure use. In fact I have just replaced my 2 x 110Ah lead acid batteries for the same again.
Because AGM need charging at a higher voltage (14.8V) than other types of lead acid batteries.Measure up?
Cheers James
The agm is 6mths oldDo you know how old the existing battery is?
The old one wants to be within a year or so old or the old one will bring the new one down to its state of charge.
I would buy a pair of regular lead acid batteries and sell/dump the AGM.
Thanks but if alternator is doing most of charging you cannot alter the voltage?Because AGM need charging at a higher voltage (14.8V) than other types of lead acid batteries.
A Detailed Guide to AGM Batteries - Alpha Batteries
With AGM products becoming more widespread in their use, knowing when you can or should use one and how to look after it properly is all the more important - our guide is here to help.www.alpha-batteries.co.uk
You would use a b2b charger to set up the correct charge profile for the battery type you have installed if it's a different type to the original.Thanks but if alternator is doing most of charging you cannot alter the voltage?
Cheers James
The B2B takes power from the engine battery and charges the leisure battery. The B2B must be set to the right charging profile for the battery it is charging. The engine battery is looked after by the engine’s ECU which controls the alternator’s output and the engine manufacturer will have set that up for the original engine battery that came with the vehicle when new.Thanks but if alternator is doing most of charging you cannot alter the voltage?
Cheers James
What gel batteries did you buy? I currently have 3 x AGM's in my Hymer and want to replace them but I am struggling to find Gel replacements.You could add a second one but I wouldn't I don't trust AGM's for leisure use.
When I took delivery of my current van I got rid of the AGM and fitted 3 Gels.
I have the Sonnenschine 78ah but the Exide 80ah are cheaper at the moment. Both made in the Sonnenschine factory almost the same battery.What gel batteries did you buy? I currently have 3 x AGM's in my Hymer and want to replace them but I am struggling to find Gel replacements.
Thank you. My current batteries are 100ah so was trying to get the same ah in gels but I presume that isn't necessary? I purchased my current MH just over a year ago and the current batteries were in it so I have no idea how old they are. They seem to manage to hold a charge with the help of the solar panels as long as I don't ask to much of them. I have a 1600 watt inverter and the low voltage alarm would sound if I tried to use a 700 watt toaster for instance. Sorry to bother you whilst on holiday.I have the Sonnenschine 78ah but the Exide 80ah are cheaper at the moment. Both made in the Sonnenschine factory almost the same battery.
Thank you again, I didn't realise using the inverter would be detrimental to the batteries life. Tbh I only tried to use it as I currently seem to have a lack of gas coming through to my grill and oven so whilst it lights that is about all it does but thats another story! Thank you for your help and advice.80 ah gel will give more useable power as you can discharge them to 20% DOD and still get a long life, compared to 50% of a standard battery.
700 Watts plus another 10% for inverter efficiency is too much for 2 batteries if you want them to last however if they are in good condition they would run it OK but their life expectancy will be considerably shortened.
Really not a good idea to to use inverters for the sake of it better to use gas for your toast.
You could run your engine whilst using the inverter thus mitigating the load on the battery????Thank you again, I didn't realise using the inverter would be detrimental to the batteries life. Tbh I only tried to use it as I currently seem to have a lack of gas coming through to my grill and oven so whilst it lights that is about all it does but thats another story! Thank you for your help and advice.
There is that except there are too many alarms that will go off unless I turn the cab seats round and lower them, bring in hab step, lift levellers (if using)!You could run your engine whilst using the inverter thus mitigating the load on the battery????
Cheers James
Our grill gives the toast a very light suntan [on a good day] . Elaine uses a really hot frying pan dry and just uses the dry pan to achieve a decent level of toasting. The low energy toaster [with the rictus grin of a hole where I burnt through the plastic wall with the Remoska ...] stays in the cupboard until we go mad and book an ehu ...Thank you again, I didn't realise using the inverter would be detrimental to the batteries life. Tbh I only tried to use it as I currently seem to have a lack of gas coming through to my grill and oven so whilst it lights that is about all it does but thats another story! Thank you for your help and advice.
The hot pan is a good idea. My smev grill/oven has always been slow but I do believe there is an issue with the gas coming in (or lack of it!). I think it is my ignorance in thinking that with the inverter, solar panels and decent batteries I could use my 240volt appliances. I was thinking of replacing my oven/grill with a microwave also but now realise that it would be a mistake.Our grill gives the toast a very light suntan [on a good day] . Elaine uses a really hot frying pan dry and just uses the dry pan to achieve a decent level of toasting. The low energy toaster [with the rictus grin of a hole where I burnt through the plastic wall with the Remoska ...] stays in the cupboard until we go mad and book an ehu ...
Steve
Happy to share with a Chi resident! Worked in Bognor Regis and in County Hall 1992-99 before starting a new life in ScotlandThe hot pan is a good idea. My smev grill/oven has always been slow but I do believe there is an issue with the gas coming in (or lack of it!). I think it is my ignorance in thinking that with the inverter, solar panels and decent batteries I could use my 240volt appliances. I was thinking of replacing my oven/grill with a microwave also but now realise that it would be a mistake.
Ah small world! How is Scotland treating you?Happy to share with a Chi resident! Worked in Bognor Regis and in County Hall 1992-99 before starting a new life in Scotland
Steve
Fabulously, thanks! It's a great country in which to live, the Scots are very friendly, supportive and helpful, and I have been able to swap a 2 miles walk to Worthing sea front for a 100m walk to the Firth of Forth and a view across to Edinburgh Castle and those 3 iconic bridges! One of the very few downsides is that I now have to drive a little more than 500 miles to reach a Cross Channel Ferry, instead of the 37 miles to Porstmouth ... But, if I had everything I could wish for, there would be nothing to motivate me to get of bed in the morning!Ah small world! How is Scotland treating you?
