Hi all anyone got any idea why the drop down bed has stopped working,checked consumer box but couldn’t find any corresponding fuses.Any thoughts on what else to look for.
Thanks will have a look around see if I can locate itThis was the solution posted on FB for a similar problem on the Adamo 69-4
"Thank you for your all comments. It was a fuse - but the fuse fir the bed isn’t located on the standard fuse board, it’s underneath the cushions behind the passenger seat. We had to unscrew the wooded panel to find loads of wire / & the fuse fir the drop down bed (20 amp).
All working now."
It’s back at storage yard something to consider.ThanksIf you are not on ehu does the 12 volt struggle? , had this issue with a Benimar
